robrdavis
Member Since 10 Jun 2011
Offline Last Active Sep 05 2014 08:58 AM
Capital Culinarian Range
02 November 2012 - 09:06 AM
I have a customer who has a Capital Culinarian series range and am looking for a service manual for it. It's the 60" (seems bigger in person though!) model number GSCR48Q or GSCR486 (not sure which, I might have written it down wrong).
The left-front burner, when turned on, will not stop sparking. I've ordered a new valve/switch for it, but wasn't able to easily determine how to get into the thing while I was there last.
If anyone can point me to the manual, or an easy way into the unit, I'd lift a beer in your name. (Darn things are hard to email!)
Thanks!
Rob
WR30X10012 Ice maker not working
25 June 2012 - 11:17 PM
I have a HotPoint HSS25IFMDCC SxS with a WR30X10012 ice maker that has stopped producing ice. I've traced out the wiring in the ice maker as per the diagram printed on the cover, as well as checked that the water valve is working. It seems as though it's not calling for water, but I'm at a loss as to what to check next.
Freezer is at 9 degrees so it's cold enough.
I have the tech manual for the unit, but other than showing how to access and replace the ice maker, it has no other info on the ice maker.
Is there a manual available for the ice maker itself? Any other suggestions?
Thanks!
