FAQs | Store | Memberships | Repair Videos | Boot Camp | Newsletter | Beer Fund | Contact
Nutterman
Member Since 17 Jun 2011
Offline Last Active Jun 24 2014 09:00 AM
In Topic: Maytag Dryer MDE8400AYW
16 August 2013 - 05:54 PM
I have this exact same problem on the same spot on the board but it keeps blowing. We've gone through 4 boards counting the original one. I don't have a tech sheet. If you've got one or any advice I'd sure appreciate it!
In Topic: ASKO washer W6021 / WM33A not spinning
10 July 2012 - 03:35 AM
I've got this washer that won't spin. My first trip I found visible burns on control board. Ordered it and replaced it. Its a 1200 RPM model with 5 rinses. I know that the correct cuts are made on the J1 thru J5 terminals. The door latch tests good and so does the pressure sensor. So I put a new motor in it. The motor tested fine but it just didn't sound right when I spun it by hand. I still don't have spin. It will turn the drum a few times CW then CCW while draining. (pump tests good also) then it pops the door open and beeps like its finished. I'm out of ideas.
Thanks for your help!
In Topic: Service Manual Request GE Frige model # ZIC360N
03 April 2012 - 07:53 AM
I don't know where they got the #. I'll just have to go out and look at it. I may not even need the manual. I just don't get many calls for built ins and I just wanted to appear like I knew the frige. :sillytongue:
02 April 2012 - 10:20 PM
They couldn't find one. I was hoping I didn't need it. I'll try again tomorrow.
In Topic: Range dual burner switch help! JES9800AAB
18 March 2012 - 12:23 PM
I love customers!!!! The wierder the better!!! I'd stand up and take a bow if I were you!!!!
