Nutterman
Member Since 17 Jun 2011
Offline Last Active Mar 11 2015 10:33 AM
Frigidaire Refrigerator model # FGHB2844LF4
27 October 2014 - 03:58 PM
I've got a Frigidaire Refrigerator FGHB2844LF4 that will not produce ice, i have checked all 3 micro switches on the ice maker, i have tested the mold heater, and the valve. the original call was for the ice maker was leaking into the ice bin. i replaced the water inlet valve then the customer called back saying it had only made 1 batch of ice and nothing after. on the return trip i found that the ice mold had ice cubes in it and they just hadn't been cycled. this has the ice maker in the fresh food section. temps are ok.
New Whirlpool Ice Maker # W10122576
05 September 2013 - 09:50 AM
Whirlpool has this new(er) ice maker assembly part # W10122576. We've just started seeing them in the last month or so. We're having to do an awful lot of warranty calls on them. The customer concerns are slow to no ice production. Our diagnosis' are landing on the ice makers but we're ending up married to these things. Anyone have any wisdom on these things that may be helpful for us?
ThanX!
MAYTAG DRYER MODEL # MDE8400AYW SERIAL # 24567823EJ TECH SHEET NEEDED
16 August 2013 - 05:32 PM
I HAVE A MAYTAG DRYER MODEL # MDE8400AYW SERIAL # 24567823EJ. IT HAS A LITTLE CIRCUIT BOARD FOR THE "INTELLIDRY SENSOR" THAT KEEPS FRYING AND THEN IT WON'T RUN. I CAN'T FIGURE OUT WHY AND IT DOESN'T HAVE A TECH SHEET. I'VE BLOWN TROUGH 3 OF THOSE BOARDS (NOT INCLUDING THE ORIGINAL ONE) TRYING TO FIGURE IT OUT.
ALL HELP IS WELCOME!
THANKS!
NUTTERMAN
Bosch DW # SHE44C06UC/38 - FD8608 last minute takes a 1/2 hour.
26 November 2012 - 09:06 PM
I haven't seen this one yet but I was hoping someone might have a good idea what to look for. Bosch dishwasher is leaving a film on the dishes and when it gets to the end of the the entire wash there will be one minute left on the display but it takes a half hour to finish.
Thanks!
Nick
ASKO washer W6021 / WM33A not spinning
09 July 2012 - 10:44 AM
I've got this washer that won't spin. My first trip I found visible burns on control board. Ordered it and replaced it. Its a 1200 RPM model with 5 rinses. I know that the correct cuts are made on the J1 thru J5 terminals. The door latch tests good and so does the pressure sensor. So I put a new motor in it. The motor tested fine but it just didn't sound right when I spun it by hand. I still don't have spin. It will turn the drum a few times CW then CCW while draining. (pump tests good also) then it pops the door open and beeps like its finished. I'm out of ideas. Mayday! Mayday!
