John Yurko
Member Since 19 Jun 2011
Offline Last Active May 07 2015 04:28 PM
In Topic: Kenmore (frigidaire) 970c42062
03 November 2011 - 09:46 AM
no....thats just it... the pump runs and it sprays the entire time.... the best was to explain is like the machine is confused as to where it is in the cycle, if that makes any sense....
02 November 2011 - 12:09 PM
intermittantly the pump didnt seem to want to come on... it would be spinning the tub as if it should be draining, yet the pump wasnt kicking in...
In Topic: Whirlpool Duet Sport HT WFW8500 DRIVING ME CRAZY!
04 October 2011 - 03:18 PM
Ok. I'm going back to that shop tomorrow to pick up some parts. I'll give that a try and see what happens! I was only assuming the mcu was ok because the shop guy told they already tried running the washer with a new one installed. I can't remember the tach circuit reading, but I do remember it was on par with the tech sheet numbers.
04 October 2011 - 01:30 PM
thats the problem. no F28 error when i tested it, (took out the ground switches, and taped em in the "closed" position. but im not getting any code at all. when i start it on quick cycle (for example) it locks the door, and it sits on 28 minutes, no fill, no agitate, no anything.... 5 minutes later, the door unlocks and shuts the machine off..... no error code at all...
In Topic: Huebsch (Amana) Washer Spins, but hardly Agitates
04 October 2011 - 12:16 PM
just noticed/wached your video....is the idler arm out of position? thats what it sounds like to me...
