John Yurko
Member Since 19 Jun 2011
Offline Last Active Jun 02 2014 09:35 AM
Samsung Fridge M# RFG29PHDRS/XAC
14 June 2013 - 05:36 PM
could anyone help me out with this? i need a service manual for the above mentioned fridge (RFG29PHDRS/XAC), the control is doing some wonky stuff, buttons wont work, then do work, then turns itself off, then able to restart, but unable to adjust temps....
Samsung Dishwasher DMT300RFW manual PLEASE!
09 April 2012 - 11:40 AM
Please help. If anyone has the service manual for a Samsung dmt300rfw dishwasher. Sending it my way would be highly appreciated
The issue I'm having is the delicate light blinks, unit won't run. First Samsung dw I've ever worked on....
Kenmore (frigidaire) 970c42062
02 November 2011 - 11:17 AM
Just replaced an entire tub assembly in this machine, now when i run it, it starts ok, fills ok, agitates ok, but the timer sometimes wont advance. when it does advance to its first spin cycle, the machine keeps filling and draining at the same time??? When you advance the timer to the final spin position, the machine spins, and wont finish the cycle either...Also the door lock takes a really long time to unlock when the timer is shut off. all these things started immediately after replacing the entire tub assembly
a little background info. this machine is at a lake lot, with water issues. when i unhooked the machine the hot valve screen was 100% blocked with sediment, the pump is very noisy (customer asked me to return with a new pump). when i swapped the tub i laid the washer on its side. could something have come loose in the chamber where the pressure switch hose connects to and is cause this stuff to happen? is that possible?
basically im asking if a bad pump can cause these issues in this type of machine?
Whirlpool Duet Sport HT WFW8500 DRIVING ME CRAZY!
04 October 2011 - 12:11 PM
Recently i was contacted to take a stab at a repair where a customer dropped off a machine for repair, the on site techs couldnt figure out, so i was called in to save the day. Yet *sigh* i was stumped too.
Basically the story goes, to the best of what was explained to me, the customer had a F28 error, the techs looked at the machine, replaced the ccu, replaced the user interface (?) board/panel... still no luck. i tested the motor, its fine, 6ohms across the first 3 motor pins, 4 and 5 tested fine, motor control tests fine.
you start the machine, on quick cycle for the sake of explaining it. the door locks, then it sits on 28 minutes and does nothing, no fill, drum wont rotate, nothing happens. 5 minutes later the machine shuts off, no error code or anything.
at one point the "add a garment" light was blinking and the machine still did nothing....
GE dryer model # dpvh880ejww
28 August 2011 - 07:30 PM
Does anyone have the manual for a GE dpvh880ejww dryer? Can't figure out how to get the top off. I know when I see it, I'm gonna be super choked on how simple it is... But please humor me, before I grab my cutting torch and "fix" this thing for the customer
