T Hemmer
Member Since 22 Jun 2011
Offline Last Active Jul 13 2011 08:41 AM
In Topic: Whirlpool Duet Dryer Model #GGW9250PW3 is Dead
11 July 2011 - 12:58 PM
I checked the thermistor from the control board plug and got 11.7K ohms at about 70 deg room temp. I ran the machine in diagnostic mode and as the dryer heated up the thermister reading went down. That seems ok. I also used an ohm meter to check the "control on button" from the control board connector and got a different resistance reading each time I pressed it. Should that reading be the same everytime I meter it?
The control on button responds to a press when in diagnostic mode.
06 July 2011 - 09:09 AM
I borrowed a known good control board and the problem remained
06 July 2011 - 08:43 AM
I checked the resistance at the thermistor with the wires removed. I'll check it from the control board tonight. Is it possible that a bad thermister circuit can cause the machine to not work at all and show no lights on the control panel or should I be looking somewhere else.
29 June 2011 - 06:08 AM
I GOT 11.7K@ ABOUT 70 DEG
