Jonathan Then
Member Since 30 Jun 2011
Offline Last Active Oct 02 2012 02:32 PM
In Topic: Diagnosing the Cause for a Twisted Door Gasket in a Front Loading Washer
02 October 2012 - 02:28 PM
Excellent informative thread! :)
In Topic: Diagnosing Bad Drum Bearings in a Front Loading Washer
02 October 2012 - 02:23 PM
That sounds terrible. 5 years and I bet that machine was close to $800-$1200 brand new... such a shame. is there any preventative maintenance that could have been done?
In Topic: Bosch she44c05uc Dishwasher not finishing cycle
31 May 2012 - 01:55 PM
Don't smash it, release all of the clips around the middle of the housing (visible here) - examine the relay pin solders (which are likely burnt) - repair it at your liesure and keep on hand to swap if and when that reoccurs.
The clips are a bit of a chore to pry open all at once - work at it carefully with a small screwdriver.
I owe you guys some beers when you come to NYC. seriously.
i took your advice, sat down with some dental picks, some micro-screwdrivers and a glass of jamaican rum on the rocks and went to work. managed to get that sucker open! problem diagnosed and confirmed!
This image is from the top side, where the burnt pin is.
30 May 2012 - 04:55 PM
Great Success!! it worked!! Thank you Guru's for all your help! when i get some time im going to sit down with a glass of scotch and pry that control panel housing apart!
576761_10150858851903017_500918016_98093545180_10150858852258017_500918016_98093
26 May 2012 - 07:44 AM
fair enough! i did try for hours yesterday to open that thing, I can get a few of the clips, but I have no idea where the other ones were, your pictures are fair at best :woot: is there a way to get me a picture of the clips? i'd be greatly appreciative of it! otherwise, i will give it another go when i have a glass of scotch and 5 hours to kill :rocker: :rocker:
