Appliance Angel
Member Since 04 Jul 2011
Offline Last Active Jun 05 2015 03:06 PM
Whirpool GB2FHDXWS01 Bottom Freezer No defrost?
24 September 2014 - 08:47 PM
Evap frosted over. Whats the procedure to manually initate defrost mode?. Heater ohms good, Defrost thermo ohms good. Unplug modules and replug. I think it needs a Jazz board but still need to know the defrost procedure. I shut off the unit at the Control board and defrosted the evap coil and while that was happening the compressor started running but it was only as I was finishing, but no evap fan running  till I pressed the FF plus button on the control. I'm still thinking the jazz board though. What do ya think?
Wpl double w/o KEBC208KSS02 control panel fusible link.
28 March 2014 - 02:26 PM
Hey guys, I'm wondering if anyone knows the heat value of the fusible link at the control panel on this wall oven. It opened and I'm thinking the reason is too much heat but usually the  hi-limit  opens due to fan issues.Thanx
Whirlpool Duet WFW9500TW01
08 August 2011 - 12:48 PM
Error codes of SUDS/ F35 . needs the water pressure sensor #W10156252/ new#W10415587. .
If Replacing NLA Part# W10156252 use #W10312527 Some minor connector / plug Modification may be required .
It works, error codes gone. Cost is less than the original.Posted Image
