BPG11
Member Since 11 Jul 2011
Offline Last Active Jul 13 2013 12:48 AM
In Topic: whirlpool, wge83301, oven not working
01 February 2012 - 01:00 PM
I wish I had the offending unit on hand and at my place. Would be more convienient that the 30 minute drive to the inlaws...
To answer your question... I believe it did, assuming I have L1 and L2 identified correctly. Should it have 120v with the control switch on too?
I have armed myself with knowledge from the trouble shooting guide and the FAQs for the next visit. Are there some 'usual suspect' parts that I could get in advance of my trip?
In Topic: Frigidaire, flat top range / oven, CFES388RFS1
13 January 2012 - 12:35 PM
Been living with it till now, I'm thinking of replacing caps on the board ... will let you know how it goes!
In Topic: Kenmore, frontload washer, 970.c43072.00
21 July 2011 - 04:49 PM
Thank you for your kind words and assistance. I am dissappointed that I shaved my forearm for nothing!!
I have cleared the hose and motor, so now it will drain, the hum is gone ... however it still won't agitate. :(
There may be some things I still need to rectify, could you help me keep digging to get to the bottom of this?
Door seems to lock when i put it on spin but still no turning...
In Topic: Frigidaire, FL washer, GLTR1670as
12 July 2011 - 03:03 PM
! found a refurbished unit (131770700) for cheap(er). BUT my controller was actually 134058400.
If both of these are replaced by 134149220, what are the chances the 131770700 will work for me? Or is there no backwards compatibility?
thanks,
bpg11
11 July 2011 - 05:06 PM
@kdog: you've found no way to get repairclinic to smuggle you parts across the border?
