eastexas
Member Since 28 Jul 2011
Offline Last Active Oct 09 2011 09:49 PM
In Topic: kenmore elite trouble 11024964301
04 August 2011 - 10:17 PM
ok mr kdog, did some poking around. traced the wires from the lid switch. gray goes to clip on overload. white goes to a splice where it is joined by two other white wires, and continues to a connector at the hot water inlet. the green/yellow is grounded under a screw. all wires appear to be fine, no cuts, burn marks, or bare wire and seem to be fitted in connectors good. what do i check now? awaiting your reply o grand wizzard kdog
04 August 2011 - 12:01 AM
ok after reading some previous posts, i have conflicting readings. just checked again- blue wire at harness to metal tub - 122, blue wire at harness to incoming gray at overload - 123, and blue at harness to white on overload that disappears into windings - .001. when i first check the blue to gray i got an 8, so touched the two probes together, went to .004 then tried again and got the 122. Is that why i got 8 the other day because i didnt touch the two probes together first?And can the overload be replaced or do i need to get new motor?
03 August 2011 - 10:22 PM
did some rechecking and found 122 volts from blue wire to ground, then from blue wire to gray (the incoming wire clipped on overload) momentarily showed 14. I then checked to ground again, then back to the overload and it showed 122. Really confused now
03 August 2011 - 11:17 AM
ok will try recheck this evening after work and the motor shaft spins easily
02 August 2011 - 10:41 PM
no agitate, spin, nothing. just hear motor hum? then a click then nothing. sounds like kdog is closing in on problem. One big problem is he is having to try to talk me thru the process and i am not knowledgeable at electricity/electronics. give me a bandsaw and watch me go
