Dedalus
Member Since 01 Aug 2011
Offline Last Active Jan 18 2014 07:46 PM
Kitchenaide KSRA22ILSS13 Ice Maker not working
18 January 2014 - 07:49 PM
The water dispenser is working. The optics check out fine. If I put water in the Ice M<aker it will freeze it and spit it out but will not then refill and continuje to cycle. I am at a loss.
Dedalus
Kitchenaide KSRA22ILSS13 Refrigferator turned off
15 December 2013 - 04:43 PM
I have a Kitchenaide KSRA22ILSS13 side by side refrigerator and it has had a long term problem of temperature control with the freezer getting way to cold and eventually building up a block of ice on the bottom. I then defrost and start again and it is good for a few months and then repeat. Well now I came down in the morning and it is off and will not go back on. I fear!
Kitchenaide Superba model KSRA221LSS13 side by side
24 October 2011 - 02:09 PM
First than ks for your fabulous advice I fixed a problem that had been bedeviling me with my GER dryer for years but now I come to problem number two. I have a Kitchenaide Superba model KSRA221LSS13 Serial number SR2427001 which is a side by side manufactured in the dastardly year of 2004. At first it was too warm in the refrigerator side and not producing ice. I turned it off (reboot) and things started working again However the internal temperature controls (electronic on the top of the inside door) never seem to do anything and in fact I cannot vary the temperature more than a degree. So a couple months go by and the freezer is getting colder and colder frosting up and meat section of the refrigerator is also freezing and of course finally the water dispenser freezes up which forces me to swing into action and reboot again (my wife is a serious drinker of chilled water). So something (the defrost system? or maybe the internal thermostat? is obviously wrong but I need your expert guidance to track this thing down.
Humbly, Will
KitchenAid Ice Maker troubles
01 August 2011 - 05:36 PM
I found the wonderful troubleshooting flow chart and following the instructions it appears I need to try to manually initiate the harvest cycle. I also found the instructions and helpful photo of how to do this with the motor jumper points but...... how do I get to that point? Is it hiding under the panel; with the blinking red light?
