mrjtwright
Member Since 15 Aug 2011
Offline Last Active Apr 06 2015 06:48 PM
In Topic: GE IM6 ice maker over filling
31 March 2015 - 01:24 PM
I wondered about that.  So, that means the thermostat remains closed long enough to bypass the power disconnect divot (thingy:) on the axle once.  It also means the tray gets filled twice.  Seems a rather inefficient design.
31 March 2015 - 11:50 AM
Thanks.  I've studied the circuitry and mechanics enough now to know 9 o clock is correct but I still picture the new batch of ice coming to rest on top of the ejector after the cycle
30 March 2015 - 11:43 AM
Well, after finally getting to see symptoms, the water does appear to be over filling the ice maker.  While the valve was not dripping at the time, I replaced it anyway since I had no other path to take.  Customer reports problem solved.  I'm still a little puzzled at the 9 o clock position though.  I appreciate everyones input in trying to help through this one.
25 March 2015 - 03:45 PM
Have you actually seen this sheet of ice?
You've already been back out once for a phantom complaint, cycled the ice maker and it worked perfectly. Are we dealing with a broken customer here?
I have not seen the ice but I told him to leave it as is this time.  Since no one seems to have any magic on this one, I will likely return this evening and install a water valve.  I don't see how it can work when I'm there and not when I'm not.  I still think the 9 o clock home position seems weird but that must be right.  I guess it could be the thermostat is not opening quickly enough
25 March 2015 - 08:16 AM
No I did not replace the valve because it turned on and off properly when I initiated the cycle. What would I check for on the waterline? It's there and looks normal. I may just replace the valve because it seems the only thing to try. Does the 9oclock home position sound correct
