Patricio
Member Since 20 Aug 2011
Offline Last Active Today, 12:32 AM
Blog Entries
Patricio's Blog > Tenacity when it does not make sense
Posted 08 June 2015
Sometimes after all the diagnostics it still does not make sense. Case in point.
Worked on an Kenmore style VMW where complaint was dead machine. Initial observation machine just sat there blinking sensing light. Put machine into Error diagnostics where Error code was F7-E5 shifter fault.
Next step put unit into manual diagnostics. Spin & agit...
Patricio's Blog > Dishwasher Pain In The Hose
Posted 16 December 2014
Dishwashers can be a pain to diagnose correctly. A recent example is a Samsung DMT400 RHS that gave me a fit with the delicate blinking light corresponding to a drain problem. Used the fast tract for diagnostics.
Reset control board (Unplug/Replug unit), put into diagnostics & went thru cycles with drain cycle toward end of service mode. Unit drained...
