SlopDaddy
Member Since 28 Aug 2011
Offline Last Active Jan 30 2015 08:11 PM
In Topic: maytag bravos washer model#MVWB300WQ0
02 August 2014 - 07:42 AM
Thinkin Whirlpool warrants the bearings for 5 years on most models
In Topic: Electrolux EI23CS55GS1 won't dispense cubes
02 August 2014 - 07:39 AM
There is a lil copper colored wire, bar that holds the flapper open. That energizes the auger motor. That "bar" sometimes comes out of the guide that lets it work properly
In Topic: GE frontload washer leaves clothes wet
21 February 2014 - 07:18 PM
I had a customer with this problem not too long ago. Turned out the cycle wasn't getting enough water. Kinda messin with the mojo control. Cleaned out inlet screens on water valve, letting more water in, then ta da.
In Topic: Precautionary Tale -- Clean your dryer vent
30 June 2013 - 10:14 AM
Ever use one of these?
Vent Testing Kit 8522199
http://www.repaircli.../8522199/831650
In Topic: Whirlpool Duet front load washer tub is cocked or sagging
30 June 2013 - 09:39 AM
If you purchased the unit in 2007 you need to contact whirlpool for service. Tell them it's making a 'Metal on Metel grinding noise during operation'. The authorized service center will need to replace the inner basket and both the front and rear outer tubs. They need to contact Whirlpool and also tell them it's making a 'Metal on Metal grinding noise during operation'. If the servicer and you don't use both of the terms and if the servicer doesn't say it needs all three of those parts then Whirlpool most likely wont pay for it. They have been pretty good about picking up those repair charges and are the only manufacturer that I know of doing it.
I've seen SpeedQueen take care of bearing issues out-of-warranty, also
