jgarb
Member Since 06 Sep 2011
Offline Last Active Sep 19 2011 03:11 PM
#208362 Medium Speed "sputtering" in Whirlpool GSX9885JQ0
Posted by jgarb on 17 September 2011 - 07:44 PM
Okay - I "rounded-up" a real Ohm Meter. and the digital readings are attached. There seemed to be no reading at all between P9-2 and other wires. I decided to pull the case and check out the connections at the motor, where I found a broken wire at a (two-wire clip Connection). See Attached pictures.
