Skiter29
Member Since 31 Jul 2006
Offline Last Active Mar 28 2015 01:05 PM
In Topic: kenmore ref Model 106.9530210 strange electrical after moving it
27 March 2015 - 12:00 PM
i did not check that as the customer said that he drove the ref a short distance and was carefull but he did lay it down so maybe the cord was damaged when he laid it down will have to check cord more closely
26 March 2015 - 10:35 PM
i checked the cord and where it plugs in to the cabinit in back by the condensor fan look good i guess i can check closer what really getting me why does the ground outlet trip breaker when plugged in and non grounded outlet it doesnt
In Topic: Frigidaire SxS Ref Model Glhs68ebsb2
08 January 2015 - 10:23 AM
ok finally got the correct wiring harness for this unit to fit the new control but now the unit runs at about 10 degrees in the ref section and the new wiring harness did come with 2 new thermisters any ideals
In Topic: WRF989SDAH00 serial K23400760 whirlpool refrigerator not making ice
23 November 2014 - 10:31 AM
yep you have a major repair coming might have a problem getting someone to do the job not knowing your area but in my last case
5 servicers refuse repair becasue of the diffuculty of the job my advise is to really get on whirlpool to get this fixed on there dime tell them
you know that this is a known problem and if you have to u will hire a attorney good luck
22 November 2014 - 03:35 PM
ok ive been on 3 of these units and the first 2 whirlpool scraped them the leak is coming from the ref evaportor the freezer goes first them the ref the 3rd one i went on i thought they were gonna scrap that 1 also but now they got a fix they replace the the ref evaporator and drain pan and drier but i refused repair becasue of danger of melting the ref compartment plastic which service will be responsable  for whirlpool was ok with that they paid a outside tech up to $500 to do it they also paid me $170 for dianostics but this one was under warranty i would if i where u call whirlpool customer service and raise holy hell to get this fixed a knowen problem for clsoe to 2 yrs good luck
