Skiter29
Member Since 31 Jul 2006
Online Last Active Today, 09:05 AM
#308063 WRF989SDAH00 serial K23400760 whirlpool refrigerator not making ice
Posted by Skiter29 on 22 November 2014 - 03:35 PM
ok ive been on 3 of these units and the first 2 whirlpool scraped them the leak is coming from the ref evaportor the freezer goes first them the ref the 3rd one i went on i thought they were gonna scrap that 1 also but now they got a fix they replace the the ref evaporator and drain pan and drier but i refused repair becasue of danger of melting the ref compartment plastic which service will be responsable  for whirlpool was ok with that they paid a outside tech up to $500 to do it they also paid me $170 for dianostics but this one was under warranty i would if i where u call whirlpool customer service and raise holy hell to get this fixed a knowen problem for clsoe to 2 yrs good luck
#305631 GE REF Model GSS20GEWJWW damper not opening
Posted by Skiter29 on 14 October 2014 - 04:57 PM
 yes it is the board, yes it has the jumper ive had this board on stock for so long the direction with the serial #s range that to cut the wire was missing and my serial # does fall in this range went back out there and i cut the jumper wire thanks for the reminder
#305180 Fisherpaykel Dishdrawer (model # tag is unreadable)
Posted by Skiter29 on 08 October 2014 - 11:14 PM
Did go back out to customer house and the error code was end up being no movement of motor checked out and found out it was a bad rotor rotor was chewed up pretty bad thanks for the help
#304982 Whirlpool Duet Steam (WFW9750W1W) no high-speed spin
Posted by Skiter29 on 06 October 2014 - 05:10 PM
Make sure you have that bottom panel on so the ground switches are closed that can cause it not to spin in high speed might be something else but panel needs to be on
#284958 Kenmore REf getting ERDH Error
Posted by Skiter29 on 18 February 2014 - 09:23 AM
replaced main board and the Sensor and it took care of the problem thanks for the help
#250858 Whirlpool Washer - Model LSR8433KQ0 - Terrible sound!
Posted by Skiter29 on 25 March 2013 - 09:47 PM
looks like bad gearcase the bottom part of the agitaor looks like its going around in circles and not back forth like it should
#250823 Recommend a good dryer review site?
Posted by Skiter29 on 25 March 2013 - 04:32 PM
been in the business for 26 yrs never like this dryer got cheaper made over the years glide problems rollers are substandard  there is a reason there is 3 yrs parts and labor part of the price your paying  and better than 50 percent chance that you will need that extra warranty just my opinon let the other experts chim in but its only one man opinion
#249609 WHP WASHER MHWZ400TQ00
Posted by Skiter29 on 06 March 2013 - 12:38 PM
replace pressure switch hose. blowing thru it is not gonna tell u if there is a pin hole in it.  i have replaced many of these that were rubbing against the tub do to poor installtion at the plant.
#249507 Maytag Bravo washer model# loud roar during spin, tub bearing replacement
Posted by Skiter29 on 04 March 2013 - 05:56 PM
ive done 2 of these first one was no problem 2nd one not so easy i the inner tub and shaft where stuck together had to really hammer to get the shaft to go up through but when it did it was still attached to the tub but when it went through seal and all came out so it turned out ok still only took me 45 min
#247981 Cabrio washer. Just purchase seal only?
Posted by Skiter29 on 07 February 2013 - 08:05 PM
why dont u buy 1 kit then go from those to buy  your off the market ones
#246629 Whirlpool Calypso
Posted by Skiter29 on 18 January 2013 - 07:32 PM
not sure which one of the Pros said this but ive read it many times here it its the correct dianostic RUN AWAY
#246368 wp cabrio wtw6600sw
Posted by Skiter29 on 15 January 2013 - 07:37 PM
lift up on the tub then try it fixed many like that also if it does come down to where you need the control board and wiring harness ive called the whirlpool tech line and they have transfered me to the  partner team and becasue of those errors they took care parts and labor but it will depend how old it is but it wouldnt hurt to call
#246280 fav6800aww Hate to even ask
Posted by Skiter29 on 14 January 2013 - 07:45 PM
i went back to customer house clutch looked ok so i called the whrilpool tech line and he walked me thru some test and he determind that it was a bad board funny thing is this control board is no longer avaible but my parts distrbuter still had 6 on hand but i talked the customer to buy a new machine she agreed
#246049 In home dryer vent
Posted by Skiter29 on 10 January 2013 - 05:18 PM
i decided i was going to also do duct cleaning as a side job needless to say that was a bad ideal but anyway this machine(brandname Rotobursh) which cost in excess of $4000 also had dryer duct cleaning attachments the first one i did was a moduler home it was down and 90 degress stright out about 25 feet thought it would be easy $100 i was there 3 hrs all this machine did was push the lint forward most of that was wet lint it did clean the duct but i was about 10 feet short of pushing it thru and i had to go in the crawl space and disconet every section and clean it about 2 pillow sack full and the 2nd one i did was about the same lint was dryer got about 6 feet short but got lucky found a 10 foot iron rod to break up the lint what really made me mad at this one was that the dryer was feet from the out side wall but the home owner did want a dryer duct in the front of the house so he vented it 60 ft to the back and what a jack ass the furnace vent was in front of the house 2 yrs later so was the dryer vent i tell customers now that i dont do venting becasue my insurance dosnt cover it if a fire occurs
#243765 Maytag Dryer MDE5500AYQ
Posted by Skiter29 on 08 December 2012 - 10:23 AM
i had one like this and the lady i went out to was relentless couldnt figure it out so i did a unconvental way i cut a piece of 2 buy 4 and i put it between the rear bulkhead and the back of the dryer and i used a self tapping screw threw the rear to hold it in place  it worked
