Skiter29
Member Since 31 Jul 2006
Offline Last Active Yesterday, 11:00 AM
Frigidaire SxS Ref Model Glhs68ebsb2
14 November 2014 - 03:37 PM
Im working on a Frigidaire SxS ref the Defrost control needs to be replaced so i order the correct one in trying to put this control the wiring harness that plugs in to the back will not go in i see the problem the connector on the board is upside down so where u plug it in it wont plug in so the little notch on top that is on the board to hold harness in is on the top but in order for the harness to plug in i have to turn the harness upside down and it will go in but only a little becasue the notch is on top its wrong thinking that they just got one wrong i went to repairclinic and blew up the picture and the one in the picture is exactly like the one i have so i dont know if there was a harness missing with my part or not anybody else HAVE this problem Model# is GLHS68EGSB2 Serial # is 4A70518311 orginal Part # 241739701 which switches to Part number: 241739709
which is the one i got
GE REF Model GSS20GEWJWW damper not opening
13 October 2014 - 08:58 AM
Im working on a GE side by side ref model GSS20GEWJWW it had a couple of problems the evaportor fan motor was not running checked control board and found that they was a burned mark on back of board put new board in and that solved that problem but now still ref section is warm so found that damper not opeaning in ref section and i know it works i seen open and close but it stays close so i change  the temp sensor and still it stays close any suggestions what is next
Fisherpaykel Dishdrawer (model # tag is unreadable)
29 September 2014 - 04:18 PM
i have a Fisherpaykel Dishdrawer model tag is half gone so no model is there hopefully this dosnt get deleted but here is my problem bottom drawer works fine but top dosnt here what i got this model has 3 buttons right by the handle you push drawer shut push start u can hear the door lock the little light will turn green and then it sits there for about 15 seconds then you get 3 beeps and the green light turns red then nothing and it dosnt fill and it dosnt try to wash, i dont work on these very often and i am clue less
GE DRyer Model # GHDP490ef1ww
08 September 2014 - 03:24 PM
Im working on a GE Dryer Model # GHDP490ef1ww dryer is less than a year old this dryer has the fuse that is connected next to the dryer cord connections it is blowing that fuse replaced fuse dosnt even last a load and it blows agian has anybody seen this what would cause this fuse to blow from where it is connected must not be a heat issue is this a motor  issue only worked on a couple of theses
Trouble with a Samsung washer Wf218annb/xaa wont Drain
02 June 2014 - 04:46 PM
ok working on a samsung WF218annb/xaa washer it wont drain every thing is clear pump is good will put in to spin only
and it will lock and just sit there at 11 min so we drain the water and then the drum will rotate and then the pump will work
when it is stuck on 11 min no voltage is going to the pump they were haveing problems for awhile before they called me they
could evently get it to pump out by turning it off and on and start and stop but now  the pump wont start unless the tub is empty
