sdskibum
Member Since 07 Sep 2011
Offline Last Active Sep 10 2011 06:22 PM
GE Monogram dual fuel range random sparking ZDP48N6DH5SS
07 September 2011 - 09:38 PM
About a week ago, our GE Monogram dual fuel range started random sparking when all knobs are in the off position. the only way to make it stop is to cut the power. The sparking jumps around between the six burners individually. *(Normal operation is that the left four all spark to light a left side burner, and the right two spark when lighting a right burner)
To make sure it wasn't due to an overflow or cleaning problem on the burners, I took apart the burners and simmer rings and made sure all the holes in the simmer rings were clear so the flame could get to the igniter. (they were clear) But since the problem we're having is that it's sparking when off, I didn't think that would help...
What should/can I try as far as troubleshooting before dropping $200 on a new spark module?
Thanks!
Kevin
