BOSTON TERRIER
Member Since 10 Sep 2011
Offline Last Active Sep 13 2011 08:33 PM
Older Whirlpool Drier Too Hot LE5600XS
10 September 2011 - 08:23 PM
Drier getting too hot. Quit heating at all. Found fuse link blown. Replaced fuse link and cut out switch ( both are mounted on the heating coil box) while I had apart also replaced heating coil. Drier still overheating. Removed vent hose from drier and tried again. Ran normal for about 30 min and started to get hot. Could this be thermostat switch and is that located on the exhaust side by the fan motor? Is there a way to check switch? Thanks for any and all help.
