abbinoxious
Member Since 22 Sep 2011
Offline Last Active Dec 11 2014 01:18 PM
In Topic: Whirlpool Mod#WFW8300SW02
17 September 2014 - 10:40 PM
I did not receive a PM... http://prntscr.com/4nvqo0
In Topic: Asko washer WL6532XXLW
24 February 2014 - 03:37 PM
This machine is starting to test my patients. Have replaced the door switch to no avail. Still says D 42 error code. Also an IE code. Cant find anything relating to this code. Any Ideas?
In Topic: Whirlpool gas range
05 November 2013 - 09:58 AM
Un sure if the broiler works. Will check it out today. The stove is new to this rental.so I am not sure as to if it worked before. Will have to find that out as well. Thank you for the files.
In Topic: mff3558veb3 Maytag fridge
22 February 2013 - 07:19 PM
Thank you exalted one. You are indeed a psychic & correct. I miss typed the #. Thank you for the tech sheet.
In Topic: Whirlpool washer model # LA5500XSN1
04 February 2013 - 07:25 PM
We checked the tub& the coupler.  Nada,  We also checked the motor like you said, (ours is hooked to a board just for this type test). The motor runs great hooked to a good machine but only humms when hooked to this one in the spin setting. Hence we feel it is the timer. Is there anything else electrical that might be bad? Besides the things we have already tried?
