wdunny
Member Since 26 Sep 2011
Offline Last Active Oct 11 2011 01:23 PM
In Topic: Kenmore elite washer #11024942300
28 September 2011 - 07:08 AM
Yes, the circuit breaker in the panel box.
27 September 2011 - 06:20 PM
Well, lidswitch checked out good. Put it all back together and drained tub. It then did exactly as you described. It started to fill up to about half full then stopped and blew the breaker. I will have to check the motor continuity later tonight as I am about to go into my second job. Do I need to drain the tub again before doing this test? Thanks so much for the help thus far!
27 September 2011 - 02:48 PM
Thanks. I didn't intentionally withhold that information. I came back and posted about the breaker as soon as I realized that was happening. I will have to figure a way to empty the washer without flooding the laundry and hallway.
I will be testing the lid switch as soon as I get home this afternoon. Had to get a multimeter first.
26 September 2011 - 06:37 PM
Another thing to add is that it is causing the breaker to trip. If I unplug the washer the breaker is fine, and doesn't trip if I plug something else in. If I plug in the washer, the breaker trips.
26 September 2011 - 05:11 PM
Correct, it is dead on all settings.
