jwj2357
Member Since 03 Aug 2006
Offline Last Active May 19 2014 11:43 AM
model kenmore 600 type 111-05 makes noise
21 January 2012 - 06:50 PM
washer makes noise during the spin cycle, like an unbalanced load? it does it all the time so im not sure its unbalanced
dryer not heating up maytag model# MDE7057AYW
22 November 2011 - 12:21 PM
Maytag dryer not heating up. runs but wont heat. its a model# MDE7057AYW and serial # 28076929YD?
do these have the heater coil at back end of drum? do u know what the reistance should be at the element?
any schematics or dissassemble instructions to open up dryer would be great,.
kenmore washer HE2 110.46472501 model
17 April 2011 - 09:09 PM
kenmore washer making horrible noise especially during spin. bearing?? how do I get to it and remove the tin work?
its a kenmore he2
110.46472501 model
hLs4636779 sn
its a nice washer front loader so id like to fix it
fridge not cooling
17 July 2010 - 03:23 AM
kenmore elite turo not cooling
model: 59673504201
sn: 11182027
fridge not cooling? was going to check evap coils after defrost. maybe a door got left open? any ideas its not that old
panansonic microwave NN-L9300
18 January 2010 - 05:28 PM
I found a bad microswitch I believe it is the "primary" microswitch. I cant seem to find one locally. the other tow check out ok (ohm wise) but the upper one is broken basically. the plastic switch frame seems intact not sure if there is supposed to be a spring at the bottom orwitch not. Id like to get the switch. I looked and found many switches on this site but not sure of the numbers. I believe this switch is a NC switch based on the drawing on the back.
need part numbers for switches and switch frame
