Richard.Noggins
Member Since 05 Oct 2011
Offline Last Active Jan 25 2015 11:50 PM
In Topic: Anode Rod for Rheem 81V80D and GE Profile PG40T9A
14 November 2011 - 09:52 PM
Here is everything you ever wanted to know about water heaters in one website. http://www.waterheaterrescue.com/
In Topic: Bradford White Electric 50gal- Model m250s6ds-1ncww
14 November 2011 - 09:27 PM
3 possibilities; Limit tripped on one element, one element burnt, dip tube corroded.
The limits are under the covers. Red button. Also remember electricity is under the covers.
Elements can be tested for continuity with a multi-meter. Turn electricity off first!
The dip tube is part of the cold water inlet. It must be unscrewed from the top of the heater.
In Topic: DSKS433EWOWH GE Compact dryer
11 October 2011 - 08:55 PM
So, in digging around in the shop looking for parts for appliances, I found a Tech Sheet for this dryer. Should I upload it?
07 October 2011 - 05:47 PM
if one of the (2) sections of the Heating Element were "open" ...
19.2 ohms on each coil. Checked the centrifugal switch, good there too. Need to figure out where the outer coil gets it power from.
06 October 2011 - 11:16 PM
No shorts, and I could not find any Tech data inside the housing, Was one of the first things I looked for.
