vunger1
Member Since 13 Oct 2011
Offline Last Active Jun 19 2015 04:28 PM
In Topic: jd630df1bb
07 April 2015 - 08:02 PM
Oops sorry bout that!
this is a follow up call after the board has been replaced twice and then it just goes dead
The ground and the neutral are wired to gether and I was trying to make sure that I did not have a short to ground somewhere causing the boards to fail. Is it correct to have continuity between any leg of hot and ground?
In Topic: Whirlpool Duet won't start cycle or unlock door
21 February 2015 - 01:57 PM
wear dat moda numba at?
In Topic: Kenmore 796.29272001 Top load washer Leaking (Same as Whilrlpool Calypso)
16 February 2015 - 03:32 PM
the hardest leaks to find sometimes are , where the fill tube may splash off of the tub ring(during fill) especially if the tub is out of balance or if the washer is unlevel. check the side of the tub (outside) for water marks.
In Topic: kenmore elite / stubborn bearing
01 February 2015 - 06:43 PM
Come see an abundance of greasy gookus.
In Topic: Washer won't change cycles
16 January 2015 - 09:36 PM
possibly a centrifugal switch
