vunger1
Member Since 13 Oct 2011
Offline Last Active Jun 19 2015 04:28 PM
#312485 kenmore elite / stubborn bearing
Posted by vunger1 on 01 February 2015 - 02:29 PM
. Look at all the grease/rust, she just kept using it even after it started the growling noise. beat on this thing for 30 minutes, never could get the outer race of the inner bearing out. Finally I just ordered the outer tub. I had to stop the noise, because im sure the customer was beginning to question my ability to finish the job.
#263379 maytag stem seal (replaced , but still leaking) mo. # lat9416aae
Posted by vunger1 on 03 August 2013 - 10:25 AM
replaced bearing kit also and all is well, as advised by those here at appliantology.org, better to replace stem seal kit and bearing kit. You dont save much by doing only the stem seal kit. Also if rubber seals on stem seal were bad,it would only make sense that the rubber seal on the tub bearing couldnt be far behind.
        Thanks to all, for the help!
P.S.  The shaft pulled out because the plastic retainer ring had been removed, by: "yours truly"
Putta tha retaina backa where a it go and as a wise Samurai once said "Konnichiwa", back in bidness.
#260523 Amana Refrigerator / bottom freezer / model aff2534few
Posted by vunger1 on 09 July 2013 - 09:37 AM
did not get video, but i did install the cntl. bd. and it has been 10 or 11 days with no complaints. Thanks for the help.
#244501 maytag dishwasher MDBH979SAM /on 3rd cntl. bd.
Posted by vunger1 on 19 December 2012 - 09:43 AM
Oh yeah, upon checking the connections at the terminal box,the white wire pulled out of the wire nut with very little force. So i tightened up both wires/wire nuts, which were copper/house-to-aluminum/dishwasher.
   I wil try to get a pic of the wiring in the house, it comes through the floor , straight under the dish washer, you have to slide the dishwasher frame over the romex(super tight fit,like you might cut the wire with the frame and cause a short tight)to get the unit under the counter. Actually 2 runs of romex come through the floor in the same hole, one for the dishwasher and one for the outlet located on the outer wall of this island in the kitchen.(same island where dishwasher is installed)
#244066 samsung dishwasher dmt300rfw/xaa
Posted by vunger1 on 12 December 2012 - 02:16 PM
Problem solved ,replaced water  fill  level sensor. Thanks for the input.
Water-Fill-Sensor-DD97-00131A--01433606.
#243809 estate dryer no power EED4400WQ0
Posted by vunger1 on 08 December 2012 - 07:03 PM
Okey (replaced timer) ,dryer is working well thanks for the help guys.
#243769 estate dryer no power EED4400WQ0
Posted by vunger1 on 08 December 2012 - 10:56 AM
You have established that you have line voltage. If this is correct, jumper your push to start switch. Turn the dryer on timed dry.Make sure door switch is closed. Put your meter probe on neutral and the other probe on timer terminal C (Bk). You should have line voltage. From there take your lead from C and put it on terminal B of the timer(LBU). Keep your other meter lead on neutral. You should still have line voltage. If not the timer contact between C and B is bad. You will need a new timer. Hope this helps.
turned out that the LBU showed no voltage,Thanks for the help ,checking to see if I have another dryer with same timer ,I will post back once it is for sure fixed.
#241666 samsung dishwasher dmt300rfw/xaa
Posted by vunger1 on 31 October 2012 - 04:14 PM
DD97-00131A
http://www.repaircli...700131A/2020870
Classic symptom of Gookus in the Sensor level assy and/or the sensor hose...
Exactly what samsung tech said ,will check that out,Thanks
#241626 ge front load dryer dcvh680ej1ms no heat
Posted by vunger1 on 30 October 2012 - 12:56 PM
turned out to be a thermister
