doivberg
Member Since 17 Oct 2011
Offline Last Active Nov 26 2011 09:20 AM
Frigidaire washer spin help GLTF1670AS0
17 October 2011 - 10:30 AM
I am having problems with my Frigidaire front load washer GLTF1670AS0 Final spin cycle. After it goes through the rest of the cycles (washing, rinse), it won't do a proper Final spin and the clothes are still soaked when it finishes. But the thing is during the Final spin cycle, the clothes are still turning, just slowly -- and I guess final spin should be fast -- and the clothes are still soaked as it hasn't drained.
My solution so far has been to reset the dial to final spin a couple times, until it works. So since it does sometimes do the fast Final spin when I do this, the washer obviously has the ability to still do Final spin and drain, it just doesn't do it most of the time.
I opened the bottom of the washer and checked the hoses and pump for clogs where they are connected. I didn't find anything, which I suppose makes sense since the washer is able to occasionally do Final spin and drain, just not most of the time.
Please help! I don't know what to check next. :S
