philmang
Member Since 19 Oct 2011
Offline Last Active Jan 27 2014 11:09 AM
Miele Commercial Dryer. Model 6351 G
07 January 2014 - 08:56 AM
Guys I have a Miele Commercial Dryer Model T-6351.G  I need to replace the drum bearing. Ano«yone help with a part number and instructions on how to replace . Any help would be appreciated.
Miele Tumbel Dryer
25 May 2013 - 11:26 AM
I have a Miele T4222C Condensor Tumble Dryer. If I used the timed function it works ok.IfI use any of the automatic functions it starts and after about 30 |Seconds the heater comes on and it immediately stops with the alarm on and Anti Crease / Finish Light on. I have checked the Front NTC and it seems ok , couldit be the Residual Damp Sensor giving problems. Any help would be greatly appreciated. Thank you.
Removing websearch from google chrome
03 April 2013 - 12:12 PM
I have what I think is malware or a virus on my system . Its a desktop running windows XP. I have just noticed that when I go into Google chrome the browser is hijacked by this Websearch programme. No matter what I do I have been unable to remove it. It is also causing Chrome to act strangely. I have tried Windows Explorer and the same thing applies here.
I would very much appreciate any help. I am not sure if the description is enough to enable you to understand what the problem is but if you need any further information just let me know. Thank you
Miele T7644C Tumble Dryer - dead control panel
27 November 2011 - 07:03 AM
I have a Miele Tumble Dryer Model T7644C . It has no power indication . Is it possible to get a maintenance manual or wiring diagram for the machine.
Miele G648 Dishwasher Intake/Drain Light
26 October 2011 - 03:39 PM
I apologise if you have this question already. I have a miele G648 with the intake / drain light coming on intermittently. Some washes go OK and then the next one may fail . I had a hard fault which I fixed by taking out the circulation pump and freeing the impellor. All seemed ok but now I have this intermittent problem . I have checked all the usual suspects , drain pump , inlet pipe etc. but all seem OK. Could it be the heater level switch . If so would be able to give me a part number for the switch. Any help would be appreciated.
