TANDCNAGEL17
Member Since 25 Oct 2011
Offline Last Active Nov 09 2011 01:54 PM
WASHER WILL NOT FINAL SPIN, WATER DRAINS, SHUTS DOWN AT 7 MINUTES AND BUZZES E47 CODE K...
25 October 2011 - 10:53 AM
Need some help from the Samurai !!, I have a Kenmore washer that will no longer final spin, water drains fine, and shuts down at 7 minutes and beeps. I have pulled a code E47 (door thinks door PTC circuit is open in spin). The door locks when the final rinse light is on, and I checked the 2 pin at the board when this happens and it is closed, which tells me its working and I should change the board, but i have read other forums (that dont drink beer, so I dont trust them) where people have had that result and replaced the board, only to have the same problem and then have to replace the door lock assy. Seems like a crap shoot, no matter the results of the test. I am leaning towards the door lock assy, just because I have had problems with them in other washers in the past. It seems to me from your web site, I should just relax, drink a beer and replace the lock assy, then if it doesn't work, return it to you and order the control board? Thanks, Tim
