Dmzauk
Member Since 26 Oct 2011
Offline Last Active Nov 08 2011 03:58 PM
In Topic: Failed Thermistor #5 PSS25MGNAWW
04 November 2011 - 08:23 AM
Thank you for the help. I guess I will replace the board and see what happens and see if it still reports a failed thermistor.
01 November 2011 - 08:25 AM
Can anyone offer any advice to fix this issue I am having?
Thank you for your time and advice.
27 October 2011 - 07:36 PM
where is the Quick Chill Thermistor located ?
I have no clue. I am just going off the tech guide and that I do have the quick chill option. But I do get a O5 reading so failed freezer thermistor and I have tried two brand new thermistors and same fault code even with a brand new thermistor installed.
Can you offer any advice on what I should do to fix this issue I am having?
27 October 2011 - 02:40 PM
I have 5 cause I have quick cool. Which is thermistor #3.
Thermistor test sequence is:
1. Fresh food top thermistor
2. Fresh food bottom thermistor
3. Quick chill thermistor (displays 0 if unit is not equipped with Quick Chill option)
4. Evaporator thermistor
5. Freezer thermistor
27 October 2011 - 01:32 PM
#5 is the freezer from the tech manual as the other user posted above. I do have the quick cool feature on my unit. I have not changed the motherboard. Is there anyway to tell if the motherboard has been changed?
So, when I run the test I get P1,2,3,4,O5 followed by a couple beeps. So, a failed thermistor on #5 (freezer).
The unit say's it is not working but tried 2 brand new thermistors and it still said it was not working.
Does anyone know what the next step is to figure out why I am getting this fail on the freezer thermistor? Could it be the motherboard is bad on that thermistor?
Thank you for any help you can offer.
-David
