VitalBodies
Member Since 27 Oct 2011
Offline Last Active Nov 13 2011 01:35 PM
My Path Has Lead Me To A Bosch WTMC3521UC, My Battle, To Install It.
27 October 2011 - 01:48 AM
TANK:
When the tank is full
and the gas flows
fire can burn softly
TANK CONNECTION:
The tank is ready
the connection not
the valve is off
REGULATOR:
Propane would flow
the regulator is missing
pressure is high
HOSE:
Gases are willing
the hose is not
rubber or black iron
FLEX HOSE:
The flex hose is short
the dryer is still
back against the wall
THE DRYER:
Bosch is sound
WTMC3521UC has value
but no tumbling is heard
THE PROBLEM:
A tank holds gas
yet no regulator regulates
the clothe do not dry
THE PATH:
The google searches
no regulator found
only wisdom brings answer
WISDOM:
To subdue the weapon
ignorance must stop
harmony prevails
THE QUESTION:
Propane for dryer
regulator not known
what to use
http://www.bosch-hom...WTMC3521UC.html
