newtech11
Member Since 30 Oct 2011
Offline Last Active Today, 07:50 PM
#287036 Maytag Neptune mah55flbww poor drain and FL error code.
Posted by newtech11 on 06 March 2014 - 09:01 PM
I haven't looked at this machine yet. Scheduled for the morning. I can't find anything pertaining to an FL code. I did find the tech sheet in downloads  but no FL. Any thoughts. Thanks.
FL mean's faulty door latch. After closing the door. The dryer tries to latch the door 6 times. If it fails to do so  a FL code is flag. Hope this helps'.
#287031 My Maytag oven delays heating then lights with a HUGE boom...
Posted by newtech11 on 06 March 2014 - 08:38 PM
My oven has always been slow to start up, but now, it delays for minutes, then when it starts is booms so loudly the house shakes. (not using the oven anymore until repaired obviously!) it is a Maytag model MGR5875QDW I would love to be able to repair this myself, my husband would be so impressed, (so would I!) Do I need a new igniter?
Katied,
I would check out where the gas leak is coming from before do anything else. You have a build up of gas in the oven cavity, which is be ignited by the the ignitor causing a mini explosion! You may have crack or broken gas line, loose gas line connection or a faulty safety valve.
#278497 Frigidaire FPHD2491KFO
Posted by newtech11 on 21 December 2013 - 05:40 AM
Happy Holidays!
Even though there is a tech sheet avalible for this model. Does anyone have a manual?
Thanks!
New Tech
#242765 Kenmore 911.4842996 27" double wall oven
Posted by newtech11 on 19 November 2012 - 08:55 PM
Sorry for the delay getting back. Thanks Jumptrout and RegUS for your assistance.
I did yank on the sensor, but could never get it down to the connection.
But there is a happy ending to this.
The customer called said the oven started working after I left, and she was very happy with the results and would call me back if she has anymore problems. Then paid me for my time! :sillytongue:
#235145 Kenmore HE2 110.46462501 Cannot resolve F28 Error
Posted by newtech11 on 27 June 2012 - 01:45 PM
Try this
Reference Status
LEDs chart, page
6-4
SERIAL COMMUNICATION ERROR
The communication between the Central Control Unit (CCU) and
the Motor Control Unit (MCU) cannot be sent correctly.
Possible Causes/Procedure
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
– Check connections of the CCU board within the housing.
– Make sure all grounding switches are engaged.
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic Test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing
the MCU connectors.
