newtech11
Member Since 30 Oct 2011
Offline Last Active Yesterday, 10:12 AM
Looking for a NLA circuit board for a Goodman PCB036100-1
13 February 2015 - 04:21 AM
Good Morning.
I don't do HVAC work. I have a friend who's circuit board went out on the above unit. They were told the circuit board #B18099-11 22488 is NLA.
So my questions is:
1. Is there a replacement/comparable board?
2.Do you know a source for NLA Goodman parts?
3. Can you recommend somebody that work/rebuild Goodman circuit board?
4. Time to go shopping? :whistling:
Thanks for any help you can provide.
Bruce
Incomplete Defrost on frt18g4awm
08 October 2013 - 01:46 PM
I am having a problem with incomplete defrosting on frt18g4awm. It is a frigidaire top mount. No electronics. It was seen by another tech who replace the defrost timer. When I got the call. The timer had failed and I replace it. I check the the heater and thermostat. The heater was distorted, but still work. I recommended that the heater be change and the customer decline at that time. Anyway make a long story short. The heater eventually failed and I replace it and the thermostat. I place the new heater into the slot on the bottom of the evaporator and secured it.
Problem: After de icing the evaporator  2-3 weeks later the evaporator is completely ice over again. I put the defrost timer into defrost mode and the heater turns on but only melts about half of the ice on the evaporator. When the heater cuts off. There is about a 5 minute pause before the fridge turns back on. I have timed the defrost timer and it runs for 20 minutes.
I have check the freezer door gasket with the dollar bill. They are find. I ask the customer about items freezing in the beer compartment. He stated normaly their is no freezing, but on occasion a item will may freeze in the back. I have check for air leaks and can't find any.
I am open to suggestions
Thanks,
Kenmore 911.4842996 27" double wall oven
17 November 2012 - 05:55 AM
I need a tech sheet!!! The model number says it is made by Roper/Whirlpool. I have the KR-30 manual for the 27 double oven, but this oven predates the manual. I would really appreciate any one with a servicematters account who can look into the archives for this. The problem is a error code F3. But the control board looks nothing like the one in the KR-30 manual and I am really trying to avoid pulling the oven out just to check the oven tempature sensor.
Your humble servant!
