Darryl Schweitzer
Member Since 07 Nov 2011
Offline Last Active Nov 08 2011 02:40 PM
Fridaire front load machine sucks in a little water then stops responding LTF2140ES0
07 November 2011 - 08:26 PM
Hello my Fridaire Front Load wash machine model number LTF2140ES0 is not running through any cycles. When I set the dial and press start the door locks and it sucks in a little bit of water and then just stops. The door stays locked and the LED's all stay on but the machine itself doesn't do anything. When I hit the stop button it unlocks the door and won't drain or anything like that. I am wondering if this sounds like a problem which could be fixed easily or if its going to be more trouble then anything else. I have an older machine to take its place but the front load has water in it and I would like to know how to drain that. I really appreciate any advice I could get on the subject thank you in advance!
