pascal
Member Since 07 Nov 2011
Offline Last Active Jan 01 2012 01:37 PM
#214790 Frost situation on Thermador Freedom 18" Freezer T18ID80NLP
Posted by pascal on 17 November 2011 - 09:23 PM
#2 You are correct, be sure to ohm it out and check for continuity, thats a drain pan heater, pretty important.
Yes it could cause, a defrost drain pan or line to freeze.
Confirmed the drain pan heater doesn't have continuity. I'll check with the vendor who supports this site to see what they can do.
