reelynyceguy
Member Since 09 Aug 2006
Offline Last Active Jan 06 2015 06:31 AM
In Topic: Kenmore 596.75512400 "SOMETIMES"cycles on the overload
20 October 2014 - 02:19 PM
Mark...Ten years is about the life on that compressor. A new relay may give you another 5-6 months, but it's basically toast. I agree with BryanS...Nice thing is, it's an easy replacement, if you have a tubing bender... :yucky:
In Topic: Kenmore 795.71023.010 Compressor not running
08 October 2014 - 04:18 PM
You sure its out of the manufacturers sealed system warranty? Some LG warranties carry out 5-7 years on parts...warranty info's in owners manual.
08 October 2014 - 05:28 AM
Replaced 3 evaporators/compressors within last two weeks for evap leaks. Sounds like sealed system to me also. Tapping the low and high side lines with a set of gauges will tell the story...
In Topic: Kenmore(WP) Side by Side Fridge 106.50512001 - No cold air to FreshFood
06 October 2014 - 04:29 PM
I've seen ice jammed in the return down behind the evap cover next to the evaporator. Physically get your fingers in there to be sure there's not residual ice in the channel. Doesn't take much...
In Topic: Kenmore refrigerator (Lg made) 795.72053.110
06 October 2014 - 04:18 PM
The ice room fan motor is probably good...just jammed with ice, causing the motor to stall. You'll have to remove evaporator cover to clean up the mess and free the fan blades. LG has redesigned the cover With a heater to prevent this problem from reoccurring in the future.
