MKeating42
Member Since 05 Dec 2011
Offline Last Active Jan 27 2013 03:37 PM
In Topic: Frigidaire front load washer FTF2140ES1 wash basin full before wash cycle sta...
27 January 2013 - 02:35 PM
Will do. Thanks!
In Topic: Frigidaire front load washer FTF2140ES1 won't spin
09 January 2013 - 11:00 PM
Woohoo! splice the wires back together, tested for continuity, plugged it back in and it works!
Thanks again for all the help.
09 January 2013 - 09:24 PM
that's not the one ...
none of the (3) listed at RepairClinic are the one you need
(wrong wire colors)
You need the one shown on the wiring diagram on the left of the Motor Controller
that connects to the Main Controller
(it has your wire colors)
134543000 is the only one on Frigidaires parts list that isn't shown ...
which is probably the one you need
Wow. that's weird. I couldn't see the part of your message with the part number in it. And you're right - I traced the wires back to the main control board:
harness_interface20130109_210231-1a_zps1
09 January 2013 - 08:15 PM
Would it be prudent to solder the wires back together? Or am I just asking for more trouble?
09 January 2013 - 08:06 PM
this one ?  $59
http://www.repaircli...R=154&N=1156892
When I search by model# RC gives me this one (Item # 1163239).
Wiring-harness-motor-control-134547600-0
But they're both out of stock.
