Rogdog1
Member Since 14 Dec 2011
Offline Last Active Dec 19 2011 03:05 PM
In Topic: Kenmore Front Load Won't Spin 417.40042990
19 December 2011 - 11:11 AM
Appliance Guru!
Thanks for the rapid advice and additional trouble shooting diagram.
With Repair Clinics wonderful return policy on electronics, I purchased the speed control board with conficence.
Five minutes after arrival, it was in the washer and the washer ran like a champ.
Thank you for everything, you run a great service here!
Rogdog1
15 December 2011 - 02:43 PM
IE8, version 8.0.6001.18702CO update version 0
Same system as original post.
15 December 2011 - 12:53 PM
Drum/motor does not move at all, tumble or spin. Thanks for the new diagram, I am not sure if I tested pins 5 to 1&9. I will try tonight.
I did inspect the speed control board thoroughly and did not see any damaged or heat affected components, of course one of the IC's could have fried on the inside.
Anything else I should try tonight?
