Rogdog1
Member Since 14 Dec 2011
Offline Last Active Dec 19 2011 03:05 PM
Kenmore Front Load Won't Spin 417.40042990
15 December 2011 - 11:02 AM
Hello Guru,
I have a Kenmore Front Load washer, model number 417.40042990. Speed control board 131770700.
The drum will no longer spin. I have gone through all of the technician trouble shooting and all systems pass.
I can manually forward the machine through a cycle, it fills and drains correctly, just won't spin in any cycle. Reading blogs it seems like the speed board is the most likely culprit, but it passes voltage, resistance, and fuse test. Is there anything else that it could be other than the speed board?
Thanks!
