dagrizz
Member Since 20 Dec 2011
Offline Last Active May 18 2015 04:19 AM
Frigidaire LGUB2642LE ice buildup in refrigerator beneath ice bin
20 March 2014 - 09:51 AM
I've got a Frigidaire LGUB2642LE that I'm working on that has ice buildup on the rear wall of the refrigerator beneath the ice bin. The unit itself is not supplied with water at this time, so I know it's not the ice maker overflowing or leaking.
I seem to recall there was a service bulletin releating to this issue at one time but I can't seem to find it. The closest I can come to is concerning the front cover not fitting correctly, which isn't releated to this issue that I can tell. If anyone could point me in the right direction or give me an answer as to what's causing this/what the solution is, I would appreciate it.
Haier top load washer...RWT360BW beeps 10 times
15 May 2013 - 11:50 AM
does anyone know how to put it in dianostics....Test program (test without water)
the service manual doesn't show?...I tried different things...got 2 leds to flash and beep 10 times
thanx
