Garpy
Member Since 24 Dec 2011
Offline Last Active Jan 15 2015 04:38 PM
#257004 Need substitute numbers
Posted by Garpy on 04 June 2013 - 01:29 PM
Oops. Forgot to thank everyone for the help. The Generic timer worked perfectly. Thanks All
#254631 Maytag Neptune No Spin MAH5500BWW
Posted by Garpy on 13 May 2013 - 12:26 PM
 Also check inertia balance switch on tub.
That was it. I had no continuity at that switch. Tapped it with a screwdriver and it worked. I replaced the part for good measure. Thank you PDuff
This machine is now fixed. :woot:
#241705 EI26SS55GS0 Fridge, Display just on and off over and over
Posted by Garpy on 01 November 2012 - 03:11 PM
Well. Got the new board and installed it. Working perfectly now. The evap fan is running fine so that's no issue at least for now. Sure pays to become a member here . Thanks to all who helped.
#220494 GE Stove GRMF3151Z, Part and Diagram missing.
Posted by Garpy on 13 January 2012 - 10:04 AM
I Googled that thermostat part number and looked at one result called 'Selfhelpforum'.....They had your range model number and there was a wire diagram listed.............told you to go to Appliance aid .com.....went there and could not find what it was listed under.......bummer............
Yah, I found that link also. Lol
I'd like to thank everyone for the help. I went by Jumptrouts ideas and managed to work it out.
I knew I could count on the help from this forum.
