wvhcrash
Member Since 27 Dec 2011
Offline Last Active Jul 13 2012 05:19 AM
Kenmore 90 Series Washer M/N 110.22922100 makes banging noise during spinning
04 July 2012 - 09:07 PM
Our washer makes a banging noise which is very noticible during the spinning cycle. It may occur during other cycles, but at a lower volume since the washing cycles are not as fast as the spin cycle. Anyway, I have looked under the washer (and did find a bolt that was out of the transmission, which I put back in and it did not correct the issue) but find nothing that is apparent causing the noise. I did run the spin cycle while I was looking under the washer (with the help of my wife) and it appears to be something between the basket and the tub.
So, I guess the question I have is how do I get the washer so that I can take the basket out of the tub and hopefully locate the source of our noise? Conversely, are there thoughts about what could be causing that noise if its not something between the tub and basket?
Thanks!
Kenmore 90 Series Washer M/N 110.22922100 won't spin without 'help'
27 December 2011 - 11:05 AM
My Kemore 90 Series washer will do everything but spin, and when it does it doesn't spin as hard as it used to. I can activate the lid switch and manually start the spinning and it will go. Sometimes if I run it through the spin cycle again, it will go on its own that time. I have reduced the size of the loads, thinking that may be the problem, but it hasn't helped.
Any help on pinpointing the offending part(s) would be greatly appreciated.
