RussTech
Member Since 27 Dec 2011
Offline Last Active Oct 30 2013 10:12 PM
#262313 temps all over the place
Posted by RussTech on 24 July 2013 - 07:53 PM
Yup, its the board. Check out core centric or another rebuilder.
#262312 GE Wall Oven
Posted by RussTech on 24 July 2013 - 07:51 PM
Self clean makes me more money then any other appliance feature, period.
#255067 F 1 ERROR WHIRLPOOL
Posted by RussTech on 17 May 2013 - 01:57 PM
Sometimes, after making sure the air dome is clear and there's no leaks, you can re-calibrate the pressure sensor and all is well. Thats only worked for me once however. Most often the pressure sensor has failed and your looking at replacing that entire control. Also, it seems like it'll give you the F1 if you don't have exactly the right amount of air in that air dome. Even with new boards that work fine.
http://www.repaircli...0189966/1469076
#254243 Thermador PRDS486GL oven control and ignitor
Posted by RussTech on 09 May 2013 - 03:32 PM
Spark Module
Part number: 486771
Part number: 486771
Gas Simmer Control
Part number: 422882
Part number: 422882
After re reading your questions, Im more lost then ever, and have no idea what you really require
#254231 Frigidaire Dishwasher (Cdn. Model BF44P1) Leaking From on Top
Posted by RussTech on 09 May 2013 - 01:41 PM
Ive seen these units leak from the back top and the top. Nothing really secures the manifold aside from molded fittings. Sometimes the top of the tub will bow in making the the fittings loose and leaking water. Try pushing the top of the tub up. Really though, you just need to pull it and run it outside the cabinetry. That will give you all the answers to all of your mysteries.
#254124 Frigidaire Dishwasher (Cdn. Model BF44P1) Leaking From on Top
Posted by RussTech on 08 May 2013 - 02:37 PM
Pull the unit and get a visual. Unless its tiled in it cant be that hard.
#253764 Cabrio WTW7340XW0 makes noise when agitating
Posted by RussTech on 04 May 2013 - 05:12 PM
Suspension rods are worn.
#253762 Whirlpool Duet Sport Washer
Posted by RussTech on 04 May 2013 - 05:06 PM
Check for correct voltages at MCU. Check for continuity on mcu wiring harness. Check windings on the motor.
Id send back Primary control. Get a good visual on the MCU. Disconnect all wires and open her up. I bet its blown a cap.
#252624 Im DUMB and need help on Kitchenaid Microwave khms2040wss-0
Posted by RussTech on 18 April 2013 - 06:52 PM
Edit: After a lot of thought I really think cactus bob has it right. If you don't understand how to work on microwaves, please don't. Its incredibly dangerous.
#252454 GE Prodigy washer Noisy during spin
Posted by RussTech on 16 April 2013 - 07:08 PM
Well, I found out. That hub nut is a bitch to remove no matter how you get at it. The bearing that you have to buy the outer tub to obtain, is just a metal sleeve. The grinding noise was coming from the lower transmission bearing. The transmission pulley bearing. Cant purchase it. Have to buy the entire gearcase which retails out at 300 bucks. I put together a new bid on just replacing the transmission and of course my customer declined. I don't recommend anyone ever attempt to remove the hub nut or the outer tub.
Edit: Even though I am a proud owner of a BRAND NEW GE OUTER TUB, I will condemn this symptom instantly in the future. I recommend you do the same.
#251869 Dacor Range Electric/Gas Combo ERD36SBK/LP
Posted by RussTech on 09 April 2013 - 02:00 AM
Part number: AP3393645
#249424 Hotpoint SxS HSS25GFPA
Posted by RussTech on 02 March 2013 - 02:08 PM
Originally, it was a burnt pin on the compressor relay. Dead box. Also, it sure did turn out to be the wire on the J1 connector pin 2. Clipped the wire, plugged her in, and she was blasting cold air through the damper into the FF side. Thanks fellas.
#239503 Where to find parts that are "No Longer Available"
Posted by RussTech on 20 September 2012 - 01:57 PM
I've recently had a barrage of wpl and kitchen aid refrigerator boards go NLA on me. Luckily I save all my circuit boards so Ive been able to send a bunch in for rebuild preemptively. Im trying my hardest to keep customers from having to wait 2 weeks with a dead reefer. This situation is only going to get worse.
#239317 Where to find parts that are "No Longer Available"
Posted by RussTech on 16 September 2012 - 07:04 PM
A lot of NLA Circuit boards can be rebuilt. Check out corecentric and fixyourboard.com
#235965 GE Energy star washer tearing the walls down!
Posted by RussTech on 11 July 2012 - 04:13 PM
Heres a diagram just for fun
