carolinainn
Member Since 28 Dec 2011
Offline Last Active Nov 30 2012 04:06 PM
In Topic: Lost neutral damage
30 November 2012 - 02:07 PM
Thanks for the help.
In Topic: Subzero 680 evaporator fan freezes
05 June 2012 - 09:10 PM
Serial # tag is gone but it is pre 181000 because it has no door open warning chime. The fan is horizontal under the coil. The heaters seem to all be working because during defrost the water thaws and drains from the collector pan with no problem. The terminator is wired as original and the terminator is mounted correctly. I checked the door gaskets and they seem fine. I'm baffled!
I'll run a defrost cycle to check that fan and compressor stop but I'm pretty sure they do. I'm still baffled!
In Topic: Subzero 680 refrigerator no serial number tag
26 May 2012 - 11:26 AM
Sorry to be so long getting back to this, I have been fixing lots of other orphan things in the meantime. Wiring diagram # is 3756372 Rev.B. I already decided it is prior to Ser.#1810000. It is R134. The manual for units prior to 1810000 does not include a 680 although the 690 is pretty much the same except for size.
