donn
Member Since 14 Aug 2006
Offline Last Active Jan 11 2015 05:07 PM
Kitchen aid double wall oven KEBS277sss04
01 December 2014 - 05:16 PM
Has anyone had to replace a hidden bake element in a K/A Double wall oven?
Any words of wisdom would be appreciated  Thanks
LG Tromm WM2277HW dE code puzzler
09 July 2013 - 04:41 PM
It all stared with rusty/corroded door hinges,
Customer was slamming the crap out of door so hard there's cracks in the plastic outer panel.
Well,  He finally called for service,  because  he started getting
 a dE code. and oh yeah and  a little white thingy fell out of door lock ,he said,  So, I get there to check out machine. . No sweat,you just need new hinges and door lock,  I said.
Couple days later I return with needed parts  (hinges & door lock )  spent a good half hour just getting the corroded screws out  the hinges
hinges on door lock replace  -plugged in machine-  set it for start--  ding ding error dE dE !!  WTF?
 so tried again ding ding  dE dE  HuH??
I checked  ALL the connections  and tried again- this time  machine started in slow spin, but the door did not lock  I could open the door and it stayed running ,wow, that's weird I thought..
So not knowing a lot about LG  I took machine back to my shop for full check out
Here,s what I've done so far:
New door lock--twice
New hinges
New control board
Checked  each and every wire end to end  (and they're connectors )
Checked drain pump
I guess my question is          What am I missing???
