tommytech
Member Since 03 Jan 2012
Offline Last Active Jul 07 2014 04:43 AM
In Topic: fridge recommendations
07 July 2014 - 04:45 AM
thanks Scott
In Topic: Imperial 60" Gas Range Model IR-6-24
06 July 2014 - 08:59 AM
did you check gas pressure? gas volume? is the orifice sized correctly or correct size? does it have an air shutter,and is it adjusted correctly?
In Topic: vct-vertical contact toaster
25 March 2014 - 04:10 AM
got it-the steel conveyor belt does stretch-snip a few links out,reinstall belts and tensioners.thanks to the folks at aj antunes
In Topic: lg washer modelwm1832cw
16 November 2013 - 09:02 AM
thank you for the replies,fixed the problem. Cheers!
21 September 2013 - 11:07 AM
heading out for this repair today,any special tools or techniques required?
