tommytech
Member Since 03 Jan 2012
Offline Last Active Jul 07 2014 04:43 AM
#256074 HOT! HOT!
Posted by tommytech on 27 May 2013 - 07:21 PM
You light up my life? (Groans)....
#251783 commercial appliance techs - advice requested
Posted by tommytech on 08 April 2013 - 08:03 AM
accepted a generous offer in commercial repair.
#250048 maytag bravos m#MVW500XLO
Posted by tommytech on 14 March 2013 - 03:56 PM
cant imagine how plastic splines could fail.....
#249876 BOSCH DRYER M WTMC3521UC/05
Posted by tommytech on 12 March 2013 - 07:49 AM
ok customer got back from vacay,went out to replace gas coils and dryer fired right up-the first time. after that no go.after much muttering offensive cuss words i found that the ignitor that i had installed previously had a couple hairline cracks in it. when it was cool,no problem,worked just fine. once warmed by heater it would not work  until it cooled off again.
#249538 commercial appliance techs - advice requested
Posted by tommytech on 05 March 2013 - 09:52 AM
m
#249421 maytag bravos m#MVW500XLO
Posted by tommytech on 02 March 2013 - 01:01 PM
thanks Samurai. btw,great service vehicle
#243530 LG Washer explosion
Posted by tommytech on 04 December 2012 - 12:52 PM
Life's Good! job security
#241652 Windows 8: Is it Great?
Posted by tommytech on 31 October 2012 - 05:29 AM
in gonna stick with mac
#241174 ge psc23ngpaww hot ff
Posted by tommytech on 22 October 2012 - 01:38 PM
i did replace board on fri, checked back today,so far no problems. frzr temp o*,ff 37*. - per customer
#240967 digital manifold guages
Posted by tommytech on 18 October 2012 - 03:28 PM
i feel the same way,my yellowjackets have served me well.it may become mandatory to have a set of these here,probably cause too many tech's dont grasp subcooling or superheat.i understand these digi's display that info for you,as well as total amount of refrigerant .
#240629 Whirlpool dryer won't dry! LER5636JQ0
Posted by tommytech on 13 October 2012 - 12:03 PM
found a dryer yesterday,customer had selector set to "fluff" cycle.never heat that way. just sayin'
#236676 Whirlpool ET22DMXBW00 Fridge not cooling
Posted by tommytech on 23 July 2012 - 09:44 AM
start with a pic of evaporator coil and post here. are both fans running?
#235431 Help! My central air unit isn't working properly.
Posted by tommytech on 02 July 2012 - 01:07 PM
sounds like you need a new condenser fan motor w/ capacitor
#235235 GE WSXH208F0WW New Spin Tub, Now Rubbing Noise
Posted by tommytech on 29 June 2012 - 10:42 AM
did you replace the rear half of outer tub? thats where the bearing is located
#235224 RHEEM 12 Condenser Fan Overheated
Posted by tommytech on 29 June 2012 - 06:53 AM
let the fan run for about 20 min,then check amp draw.if above rated draw inc. + /- %, i would replace motor and cap.
