woftam
Member Since 11 Jan 2012
Online Last Active Today, 07:08 PM
In Topic: Subzero 532 cooling fine but the compressor runs all the time and is very hot
12 February 2015 - 06:24 PM
Is the condensor fan running? Should be running if either compressor is.
In Topic: Sub-Zero 700 TC refrigerator compartment too cold
27 January 2015 - 07:54 PM
Sounds like relay for ref section is stuck closed. Need serial number.
In Topic: Wolf CP36 G/S Counter Range Igniter trouble
01 December 2014 - 09:22 AM
Sorry wrong model. There should be an access panel on bottom back right for modules without removing top. Would need correct M/S numbers for parts.
In Topic: Sub-Zero 511 refrigerator S/N M114......
01 December 2014 - 09:15 AM
4202530 this is heater package for 550/650. Floor panel will need to be cut to fit 511.
30 November 2014 - 12:18 AM
CT36 should be sealed burners. Two torx screws under caps to lift burners and pan off. Spark modules are under pan.
