skenig
Member Since 19 Aug 2006
Offline Last Active Oct 26 2013 08:25 PM
In Topic: Dryer GE DSXH43EFOWW tumbles, no heat
26 October 2013 - 12:41 PM
Vent pipe is clean. I will check wiring at terminal block and also continuity of heating coil.
In Topic: dsxh43ef0ww GE dryer noisy drum
25 October 2013 - 02:56 PM
Removed drum w bearing from machine, unscrewed shaft from drum, rear ewes I'd properly, put the drum back. Machine is purring. ;-)
27 September 2013 - 10:19 PM
Follow up on my first post. After staring at the schematic of the dryer ( http://click.linksyn...sxh43ef0ww.html )
I unscrewed the drum from the shaft suppport because i could not lift the drum otherwise; it would not let itself be lifted.
In Topic: Magic Chef CGR3740ADH stove convert to natural gas locate orifice hoods
05 October 2011 - 02:39 PM
Many thanks! Once I located the orifice hoods, it was easy to untighten them , and now I have a beautiful big blue flame!
I bow to your knowledge, wise Fermented Grand Master.
05 October 2011 - 09:29 AM
Thanks, RegUS, but that does not say where the orifice hoods are located, which is what I am trying to find.
