nathanstaab
Member Since 30 Jan 2012
Offline Last Active Dec 04 2014 09:50 PM
In Topic: Bosch NEXXT 300 Washer - Slow cold water fill
11 November 2013 - 12:19 AM
If the screen in the valve is clean and no blockages in the hose or kinks. Replace water valve. Usually if your on a well you get sand and other deposits that slow the flow of water into the machine.
City water here, but there has been an instance or two - where a load was done late at night while the water softener was doing a regen - I wonder if that took it's toll with some small pieces of resin - can you verify that is the proper water valve?
Thanks.
In Topic: Electrolux EWDW6505GS0 Error Code 3 - Wash Pump
11 June 2012 - 03:14 PM
Thought about it, Since it's a variable speed motor I was thinking the tach sense on it might be defective.. no easy way to test that without putting it on my test bench.. new wash pump ordered, I'll keep you informed.
Thanks sir.
